Compare Models - BIMCloud
hi all,
Can I compare a TeamworkModel with a snapshot of its own (.pln or .BIMProject24)?
In the Model Compare Window under Select Model 2 ... I expected to access exatly that, but all I see is that my models are all greyed out.
BR, Florian
AC24 4018 INT, Win10, Quadro P2000, Xeon, BIMCloud
3 Replies 3
I think you can select only TW Projects from the BIMcloud Server, but not their snapshots (which are basically backups).
Maybe you could try to download the PLN snapshot to your local machine and select that PLN file to be Model 2 in the model comparison.
hi Laszlo,
yes, that is the workflow I used then.
Would be useful to compare current model with its backups - but not crucial.
Thanks for the feedback
BR, Florian
You can always make a wish.
