Deleting Teamwork Project from local ArchiCad
Hi everyone,
I'm working on some AC13 teamwork projects. I need to get rid of some, so I deleted them from the BIM server using the control panel.
Now I need to delete them permanently from the local machine, that is, from the local ArchiCad. (the names of the projects I deleted on the server still show up in the teamwork/join project menu).
How do I do that?
Thanks!
Enrico
1 Reply 1
Just try to connect to the server with the
local copy. During the joining process you are informed
that the project has been deleted from the server and
a possibility to delete the local copy as well is offered.
Hope this helps.
Regards, Juha
