Teamwork & BIMcloud
About Teamwork, BIMcloud, BIMcloud Basic, BIMcloud Software as a Service, network settings, etc.
Error Regarding Client Server Version
When trying to share a new project in Teamwork, I receive the error "Your Client is not compatible with the selected server. Server Version:14.0.3004, Client Version:14.0.3269" I assume this is because I recently installed the AC 14 Hotfix 3269. I've attached a screen shot of the BIM Server control center, showing that its build is 3004. How do I get the BIM Server to update to the same build that AC is running, 3269?
1 REPLY 1
Link
That's exactly what it is. All client and server builds must match identically, so run the hotfix on your BIM server also.
Link.
