2019-11-13 02:31 PM
2019-11-14 11:54 AM
2019-11-14 12:32 PM
Christophe wrote:
Hello AEismann,
BimServer is called now BimCloud.
BimCloud migrates all model elements to editable elements for all the work team.
BimCloud is often heavier than the same project by a PLN file.
I've allready saved a PLN from the Teamwork BimCloud to :
- delete all unused views
- delete all unused attributes
- delete all unused documents
- delete all unused library parts
Then I've uploaded this cleaned PLN back to the BimCloud
The teamwork project's weight was divided by 3
Since when do you keep this project on your bimCloud without cleaning it ?
2019-11-14 12:38 PM
Noémi Balogh
Community Expert, Admin
2019-11-14 12:56 PM
2019-11-14 12:58 PM
nbalogh wrote:
What Christophe mentioned are all good ideas, and let me recommend some other:
- keep Embedded Library size 0 kb - store IFC related objects in a BIMcloud library,
- regularly Send & Receive with all users,
- Force leave long time inactive users from projects,
- Re-share projects after an Open & Repair when you feel that file size could be reduced.
2019-11-14 05:24 PM
[/quote
Great ! Absolutly !
And if it's true, you can stop for "book everything" to ease the data processing
