Teamwork & BIMcloud
Fills return to front in interior elevations
Has anyone encountered this issue?
So far, it has only happened in our TW2 projects (I would've posted this in the TW2 topic but I figured it could happen in solo projects also) - a couple users have placed drafting fills to represent wall finishes in select interior elevations, and toggled the display order to show it properly. For example, a drafting fill representing tile in an bathroom has been drawn in and by default, it's up front. Display order changes are then applied until the tile is between the wall and toilet objects.
Through several occasions among a couple TW2 projects, the fill has returned to its default position and shows in front of the wall and toilet objects. We cannot determine when it occurred, although send and receive changes have been done in between. It has always resulted in going back into the IE and toggling the display order again.
Just checking to see if anyone has this issue and of course for resolutions, if any. Can I change the settings of the display order for interior elevations only? If yes, where do I find that?
Erika Epstein
You should post this in TW. Sometimes funny or not so funny things Happen in TW that don't happen in solo projects.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks, Erika - will do. I usually hesitate on creating multiple threads on one topic.
I moved the topic for you to the TW forum.
