ā2009-09-17 08:20 AM
ā2009-10-11 09:50 PM
ā2009-10-11 10:00 PM
ā2009-10-12 08:16 AM
Dennis wrote:Yes. It works great and is very easy to install and use. EXCEPT if you want others to be able to sign in from outside of your local network.
My employee was able to start using TW2.0 for work after 5 minutes of quick introduction. Besides the technical part of setting up the BIM server, the actual user's learning curve couldn't be any easier in my opinion.
Hats off to GS, great job and great release.
ā2009-10-13 10:39 AM
ā2009-10-13 04:27 PM
Holger wrote:This is incorrect. While a static public IP is one method, a dynamic IP can be used equally well:
Your Server has to be accessable from the outside, therefor you “need a static IP.
GS has made a good archicadwiki about it.
http://www.archicadwiki.com/Teamwork
ā2009-10-15 06:10 AM
Steve wrote:Yes I can. Initially, I had my BIM server name use the "computer name", which worked fine within my office. I then wanted the option to access the BIM server from outside without a VPN connection, so I changed the server name to MYCOMPANY.dyndns.org, and did all the necessary things as mentioned in the WIKI article.Dennis wrote:Yes. It works great and is very easy to install and use. EXCEPT if you want others to be able to sign in from outside of your local network.
Are others able to sign into your BIM Server projects from the internet?
ā2009-10-15 06:31 AM
Dennis wrote:Hi Dennis,
After I changed the name of the server to the XXX.dyndns.org, which esentially is the same computer, same BIM server with just a different name, I was not able to access any of the alrady uploaded BIM server libraries when I connected via the internet w/o the VPN. I had to re-share the project with the XXX.dyndns.org named server, in order for me to access the BIM libraries from the internet.
All of this of course, is in the WIKI article already.
ā2009-10-15 01:54 PM
ā2009-10-15 07:43 PM
I think part of the confusion I had was between the two library dialogs, one from the traditional "Library Manager", and the extra "Manage BIM Server Libraries". In my previous case, I could see the libraries in the "Manage BS Libraries", but they were "Unavailable" in the "Library Manager". Another weird thing was the fact that the work computers had access to the libraries even after the server name change. Is this because I changed the "hosts" file on them???
ā2009-10-16 12:35 AM
