Modifying Layer combinations and adding layers
Currently using Archicad 15 teamwork.
I changed a user role from draftsman to lead architect in the BIM server manager thinking that he'll have rights to modify layer combinations and layer changes. And also checked project administrator and server administrator before closing.
I turned off the BIM server and restarted it thinking it will work.
When the user goes back into the Teamwork project, he is still unable to make any changes to the layers and combinations.
Does anyone know how I can give him the rights to make the changes?
Thanks!
5 Replies 5
Aaron Bourgoin
dumb question I'm sure, but, did you reserve them?
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 30 / AC29.2.1 COLLABORATE AC30.0.0 COLLABORATE
Rhino 8.36 Mac
MacOS Tahoe 26.6.2
Yes. He has reserved all, and he still is not able to create layers and or modify layer combinations.
KenMcN
Don't you need to leave (i.e. sign out of) the project before the new role takes effect? Not sure if he did this or just closed the file and reopened it.
Kenny
V25 & 26 (fully patched); Mac Ventura, MacBook Pro M1 Max
Eduardo Rolon
Kenny
Yes. You need to leave and rejoin.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Thanks all,
Yes, this worked. I thought it would automatically take affect when the colors were changing for the user. This worked!
