Pdf Publisher
I am working in Teamwork ArchiCAD 15, and would like to use publisher to create pdfs. I have done this very easily in non teamwork files. I can create a new folder but it does not let me add to an existing folder. I have tried reserving the whole file and I am still unable to do this.
I read on the forum that various teamwork member have different status that could affect this. But i do not know where to check what my status is.
Has anyone else had this problem - any solutions be much appreciated!
Thanks!
10 Replies 10
NCornia
Graphisoft Alumni
Graphisoft Alumni
Prashilla,
Just to clarify, because the Publisher Set Teamwork Status is not immediately visible, have you clicked on the arrow next to the name of the publisher set to then take you to the "Public Sets Management" dialog? Here you will see all publisher set names listed and it is here that you will see the Teamwork Status and the Reserve/Request button for the actual set. I cannot be sure if you have visited this specific area from what I gathered in your previous posts. See attached image. Also note that when you perform a Reserve All operation a dialog appears that lists the results of said operation. I wonder if some poor soul in your office has reserved the Publishing Properties unknowingly and locked everyone else out. If so you will see a red dot under the "Conflict with others" column. I'd be interested to know.
Also here is our Help menu page on this specific topic: http://www.graphisoft.com/ftp/publishing/ac15_help_INT/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=...
Best regards,
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
