Problems with hotfix 3636 BIM Server AC14
I've just installed AC14 BIM Server (i used before AC13) and after running hotfix 3636 only BIM Server Manager was updated. BIM Server has the version 3262 but clients and BIM Server Manager have 3636. With this i can't work in Teamwork. I have 1 server and 2 clients.
Any help?
Don't know what happened but uninstall and install again solve the problem.
Thank you anyway.
Erika Epstein
You, your clients and the BIMserver all need to be on the same build.
Is there a reason you are not updating your build to match the others?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
