Teamwork & BIMcloud
Recovery file of Teamwork project on MacOS.
rodut1112
After more than a decade of using AC, half of which using it on MacOS, i still have the same issues over and over and over again. This one is regarding the fact that if you have multiple projects open, in my case Teamwork projects, if one of them crashes, there is no way of getting to the main "splash screen/startup dialog" to have access to the recovery file of the project that just crashed. If you go through the "join teamwork project" process, it just reloads the file from the server and not the local recovery file or even worse, it fails to merge information which leaves me with the option to discard or save as PLN.(not a viable option)
The only way is to close all projects.Quit all archicad apps and only then start AC again to get to the recovery file, marked in red. It`s really time consuming when working on multiple files and one crashes. Also why.....for our mental health sake, why do all the AC icons stay in my dock. If it happens to open and then close 10 projects side-by-side, after i close everything i am stuck with 10 AC icons. It might be a MacOS thing, which proves how hopeless and annoying Apple really is, but i`m sure its not happening with any other software.
It might sound like a rant, but please GS, pretty please, can you actually make something work logical. Your support for Apple/MacOS has been advertised for YEARS. The product is still lacking.
Maybe i`m doing something wrong, but our local archicad supplier couldn`t come up with a solution for this either, hopefully the forum knows better or GS implements it in AC 35.
Archicad 23/25/26 NL , MacOS 13.4.1 (c) on MacStudio M1 Max
fabioferrini
Same problem here!!
Fabio
Maxam
Yes, this just happened to me and I've lost hours of work an account of how unclear it is what to do when your Teamwork file crashes and doesn't open up with a life preserver recovery option.  Really sick of this software stealing so much of my time.
Aaron Bourgoin
if you are running multiple sessions of ac and one crashes, go to a running session and do a File: New. Select a template file and start a new session. If there is a recovery file you will be presented with a dialog to open it.
This was a happy accidental discovery.
Think Like a Spec Writer
AC4.55 through 29 / USA AC28 USA
Rhino 8 Mac
MacOS Tahoe 26.0
