Teamwork & BIMcloud
Reservation Assistance
Hi all,
We are a small firm with 5 Imacs working with Archicad 21 and Bim Server.
I want to update to Archicad 22 and BIMCloud Basic, but I“m still not sure.
What does it mean that the basic version doesn“t has "Reservation Assistance"? It means that I can“t see who has de object reservated? I can“t ask for it?
Thanks in advance,
Alicia
Arq. Alicia Hilman
Pensaer Bim manager
Eduardo Rolon
Reservation Assistance means ± Autoreserve of elements instead of your current workflow of having to reserve manually an object for BimCloud "Pro" it will try to automatically do that step. So upgrading from 21 to 22 reservation will stay the same.
https://helpcenter.graphisoft.com/user-guide/77147/
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
4 REPLIES 4
Eduardo Rolon
AC29 US/INT -> AC08
another Moderator
Thanks for your answer ejrolon!
What does Bimcloud basic then? the same?
Eduardo Rolon
BimCloud Basic works the same as BimCloud in AC21
AC29 US/INT -> AC08
another Moderator
Thanks
