Teamwork & BIMcloud
Server Pairing function missing
I have installed the new version of BIM cloud in the wrong order. Manager first, then Server. The manager gave an error that it doesn't have paired server module. In help files I found this solution:
https://helpcenter.graphisoft.com/user-guide/83121/
As it turned out the plus sign in the current version is missing... how can I fix it then (besides reinstalling the whole thing
Noemi Balogh
It is "missing" because this is the feature of the licensed BIMcloud and not available with BIMcloud Basic.
To fix it, upgrade to BIMcloud, pair the BIMcloud Server based on the article you mentioned and downgrade in the end.
Kind regards,
Noemi
NoƩmi Balogh
Senior Community Expert, Admin
Noemi Balogh
Kind regards,
Noemi
NoƩmi Balogh
Ok thx
I just reinstalled
Works again.
