2009-10-10 03:22 AM
2009-10-10 05:03 AM
2009-10-10 05:22 AM
2009-10-10 05:40 AM
Dennis wrote:Does that mean that people out side of your network can sign into your BIM Server via the internet?
So far, I've tried the BIM server with a VPN connection without a problem...
2009-10-10 06:10 AM
Steve wrote:Apples and oranges - the IP address has nothing to do with port forwarding.
Is having a static IP address any better than using the port-forwarding work around?
2009-10-10 06:14 AM
2009-10-10 06:15 AM
Steve wrote:A VPN (Virtual Private Network) allows full access to the office network as if the user was in the office on the LAN. So, yes someone outside authorized for the VPN could use the BS. But, more important, they can access the office file server. Most users are just learning about TW2 so far ... but once folks try hotlinked modules and external placed drawings, they will realize that a VPN could be a very useful thing, because the BIM Server does not 'serve' those things.
