Teamwork & BIMcloud
Sticky note - how to get it to pop up on screen?
rob2218
I saw this in a webinar meeting.
How do I get the "sticky" paper note to pop up on the screen when messages are sent to users?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
4 REPLIES 4
In the Work Environment Dialog, More Options page.
You need to enable the "Show New Message Alert in Teamwork" checkbox.
When it is enabled then messages will appear like that.
Normal messages appear for a few seconds then disappear.
Messages sent with High Priority do not disappear until the receiver clicks them or does some action with them.
rob2218
thank you sir.
Now....do I need to enable this on everyone's MAC or is it a global network setting?
I presume it'll have to be done on each individual MAC station.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Yep, because it is a setting in the Work Environment.
You may export/import the Work Environment if that speeds it up.
rob2218
much thanks.
wow...that was a quick reply.
I'm watching that webinar that shows multiple users collaborating all over the world....very interesting.
i>u
Edgewater, FL!
SOFTWARE VERSION:
