‎2010-07-26 08:52 PM
‎2010-08-03 04:40 PM
‎2010-08-03 08:49 PM
‎2010-08-03 09:35 PM
‎2010-09-03 02:18 PM
‎2010-10-11 10:09 PM
gkmethy wrote:There does not seem to be much information about using the TeamworkServerBackupTool. I understand how to run a backup in the terminal from the ArchicadWiki article but, if I wanted to automate the process, how would I go about writing a script to perform a complete BIM Server Backup every day at a certain time on our BIM Server? Would new backup overwrite data from previous day if path is the same?
I understand that using a separate backup tool for the BIM server when you already have a backup system in place may seem redundant, but there are several cool things about the TeamworkServerBackupTool:
- It knows exactly what files to back up. You don't have to worry about specifying anything else than the target location of the backup.
- It backs up not just the Projects, but Libraries, Users and Custom Properties as well
- It works with the BIM server running. It recognizes if a project is in use, and waits till it's accessible. Users may only notice a short "server offline" while a project is being backed up.
- You can use it to restore just certain projects, or a whole BIM server. You can also restore projects to an existing BIM server, in which case it will add the projects to the existing projects on the server
The only drawback is that it only works with the ArchiCAD 14 BIM server module. It does not support ArchiCAD 13.
‎2010-11-23 08:55 PM
‎2010-11-24 11:13 AM
‎2010-11-24 12:20 PM
