ā2009-10-15 10:44 AM
ā2011-12-27 01:49 PM
ā2011-12-27 10:33 PM
ā2011-12-28 09:39 AM
ā2012-01-30 07:30 AM
Achille wrote:I had similar issues here! I select all roofs (in 2D because there are errors in generating 3D), then deselect every roof + use F5 to check what roof was cause error. It's sound like a "manual way" but it worked!
Thanks Laszlo, I tried your suggestion but it didn't work.
I found the invalid elements from the 3d window error message and deleted them. They were more than 10, but anyway I solved the problem.
