TW error - invalid elements
I've got a message "Save Error". this message can see in pic. it pop up after few day, when was created the TW file. When I tray the follow of the message information. the situation have not change. I can use this file still.
Can any to help me with it?
4 Replies 4
Achille Pavlidis
I have the same problem... same message appears every time I save...
when clicking on the magnifing glass icon a web browser page appears that shows the invalid elements...
who do I get rid of those invalid elements?
I cant share the project with those still in...
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
Try this:
Go to 1. Story.
Select All Roofs (hopefully this will select even the buggy Roof even though you cannot find it).
Cut to Clipbaord (CTRL+X)
Paste back.
During pasting ArchiCAD usually tries to fix incorrect element data.
This may work.
Achille Pavlidis
Thanks Laszlo, I tried your suggestion but it didn't work.
I found the invalid elements from the 3d window error message and deleted them. They were more than 10, but anyway I solved the problem.
I had similar issues here! I select all roofs (in 2D because there are errors in generating 3D), then deselect every roof + use F5 to check what roof was cause error. It's sound like a "manual way" but it worked!
