Achille Pavlidis
TW layer problem
Today after receiving, all my layers got messed up.
The layer combination in each vies appears fine, but all layers are visible in every view, plus:
  • every element is shown as being in a "Missing" layer from its Info Box, but the pop-up window displays its correct layer.
    Selecting all layers and making them visible/invisible does nothing
    The layer list that appears when clicking on the drop-down menu from the info box contains much less layers that there are.
    From the layers command the list appears normal
[img][/img]
Mac OS 26.4 | AC 29.2.1 INT 5101 FULL
Marton Kiss
Achille,
if you still have such state of a project, please create a support package - based on that we will check what might have caused it (will PM an upload link to you). After the package has been created:
- try to re-load the project from server - leave project, then join it again
- if this does not appear to be helpful re-share the project from a pln
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
