TW2- Where are the step-by-step instructions?
In reviewing the Archicad 13 Collaboration Guide, I cannot locate any sections that explain how to share a PLN... and so on.
I have figured out most of TW2's functionality via web seminars and trial/error. But what is concerning me is the lack of documentation on how-to and best practice.
For example, once the PLN is converted to a shared project via BIM Server, where is the shared file located? And is it necessary to keep the original PLN? In testing, we deleted the original PLN and the shared connection still functioned, but I have nothing to tell me that I am right or wrong.
Please help. Thank you.
Christopher Humes
Richmond, VA USA
14 Replies 14
Steve Jepson
Something that is not clear to me is that when I open the hosts file in Notepad (C:\Windows\System32\Drivers\Etc) it appearsears to be a sample of how a HOST file looks. Is this Notepad window actually the place to edit someting?
Obviously a static IP address on your router is best, however, if you dont have one it is not that big a deal to send out a new link to the BIM server if it is only going to change once every few months or so.
The dynamic IP address that Comcast issues (for example) can not be called static IP address but they don't change very often.
Port Forwarding is what needs to be configured if you have a static IP address or not right?
I don't know how to do that but it doesn't seem like it would take much to give step-by-step instructions.
This may be of some help.
http://corz.org/comms/hardware/router/static.ip.address.php
Hi Steve,
Yes, the article that you link to gives directions for assigning a static local address to a machine. This is useful in all cases, but it is essential if you are going to edit the hosts file in order to point a domain name locally to a particular machine... if the machine were dynamically assigned an IP address, then local access would break...in the specific scenario where local access requires editing the hosts file due to concurrent internet access. (As noted in the wiki article, this may not always be required depending on a number of factors.)
Yes, the notepad window contents that you see is not a sample ... it IS the hosts file. The first group of lines is just documentation - anything after a "#" symbol is a comment and is ignored during processing of the file. Edit carefully.
AC 29 USA and earlier   •   hardware key   •   macOS Taho 26.5 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Steve Jepson
Thanks Karl.
This will be a sweet victory when I finally get it up and running
It does not make it clear anywhere in the ArchiCAD 13 documentation that the original project file is obsolete once a project is shared. It's going to affect how we file our projects and is a quite alien and new process that even long term users of ArchiCAD won't find intuitive or obvious. They really should make it much clearer.
Hi!
I think it will be helpful if somebody can specify with examples the path of a general TW2 installed on a single computer in a local network.
Like C:/Projects.....and so on.
Thanks
