gdford
TeamWork clickon and drag and object to reserve the object
Archicad V25
I have used teamwork since version 10 and I just now noticed that if I click on an object and drag it the object is now reserved...
How long has this been a feature?
Is there anyway to turn this feature off.?
thanks
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
3 Replies 3
Noemi Balogh
Reservation assistant is available for BIMcloud and BIMcloud Software as a Service, a feature added with Archicad 22.
You can turn it of in Options / Work Environment / Data Safety & Integrity... with this checkbox (available only when you are connected to a Teamwork project):
Noémi Balogh
Staff Community Expert, Admin
gdford
cool beans - Thank you Noemi!!
I assume that it needs to be turned off prior to teamworking the project for it to be off by default to all team members.
is this correct?
Gary Ford
Archicad 12-26
(RAM) 128 GB
NVIDIA RTX A2000
Noemi Balogh
This setting doesn't connect to the individual project, but the subscription type of BIMcloud is used. You might edit the default Work Environment setting when you deploy Archicad, but other than that each individual can turn auto-reserve on or off, whenever they want, you can't centrally control it.
Noémi Balogh
