TeamWork in Archica 21
Hi! why takes almost 5 minutes to reserve all in archicad 21?
My file is only 962.3 MB.
I am doing something wrong?
Thanks
4 Replies 4
felcunha
Normally no.
It's hard to answer without more precisions... is your archicad up to date ? How's your network ? Where is your BIM Server installed ?
Felipe Ribeiro Cunha
AC 26, macOS Monterey
Marton Kiss
5 minutes for the reserve all command sounds quite extreme.
As a first step save out a pln from the project and share it again. This will help to clear out the reservation table. If the error remains after this I recommend to get in touch with our local support team for further investigation.
Marton Kiss
Chief Product Officer
GRAPHISOFT
Thanks for your answers I will share again.
Hi sorry for the delay but I try to follow your suggestions and stil the same story evenI contact graphisoft in USA and they still not give me an answer.
In addition of that in 3D view I have the following window, and I run Teamwork Archicad with the most released patch # 5021
Thanks
