Whew. Glad that resolved it! I couldn't think of any other possible reason.
So, to clarify this for others finding this thread... did your Role / access privileges get modified while you were logged into the project? If so, then we should check to see if this is a bug, or if the system is designed so that you must log out and log back in for changes to take effect.
AC 28 USA and earlier • macOS Sequoia 15.3, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
One of the forum moderators
