Teamwork 17
Hi! I am working in a project in teamwork with Arch17. I have everything reserve, why I cannot change or modify some materials?
Please HELP!!!!!!!
Thanks
5 Replies 5
Do the Role Settings for your Teamwork user account allow you to modify attributes?
http://helpcenter.graphisoft.com/guides/graphisoft-collaboration-guide/collaboration-solutions-in-ar...
http://helpcenter.graphisoft.com/guides/archicad-17-int-reference-guide/collaboration/teamwork/bim-s...
Thanks, Yes I already checked and I have all the roles available.
Sorry! Karl
I checked again the roles and I log out and in again and now it work.
Thanks for your hint.
Whew. Glad that resolved it! I couldn't think of any other possible reason.
So, to clarify this for others finding this thread... did your Role / access privileges get modified while you were logged into the project? If so, then we should check to see if this is a bug, or if the system is designed so that you must log out and log back in for changes to take effect.
Karl, you need to log-out and change the roles and log-in again.
Thanks
