Read more
Teamwork & BIMcloud
Teamwork ArchiCAD 16 and ArchiCAD 17
Hallo can someone tell me how is it possible to use Teamwork between ArchiCAD 16 and ArchiCAD 17. I tried oto use it with my college and to work with it but it doesent funktion because of different version!
Best regards Nico
It will not work, as not only do you have to be using the same version of Archicad, but the same Hotfix (update) also.
Have the same experience, and I'm very annoyed why the Version are not compatible!!!
sedley
Best regards Nico
If bimserver 16 is install and you install bimserver 17, there will be two modules on the bimserver.
you can then use both AC16 and AC17 files.
However, you cannot open TW16 file in AC17 .
File shared from AC16 will only open in AC16 unless you save a .pln then share it from AC17.
Hope that helps.
Sedley Jeffers
St.Vincent & the Grenadines
Archicad 26 Full USA - Cadimage & Twinmotion
MacBook Pro M1 16", 64GB RAM. OSX Monterey
