Teamwork - Story markers, grid, etc. - problems
I'm working in AC15 on a teamwork file and it seems to be real buggy.
Examples: Two of us sign in and the story levels are showing correctly on one computer (in elevation) and on the other computer they show differently. The marker heads are displayed on one computer and not the other. When I sign out and come back in, they may or may not be correct (no logical explanation).
I changed the sheet numbers of some sheets and send/receive only to come back later and find they're showing different on my computer, but not the other. I sign out and sign back in and they're correct, or again, may not be correct.
There have also been some display issues (text overlaps sometimes when scrolling through folders in the project navigator).
Is this just new release bugs or am I going crazy? Should I check my vision?
4 Replies 4
David Maudlin
Steven:
Based on the build # listed in your signature, you might want to take a look at this thread:
What is the current build number?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thank you, I saw that link and am a little confused by it. I'm a little hesitant to download a hotfix that graphisoft themselves have not released, or have they? I talked with Graphisoft North America and they had no idea about the 3006 build (though I was just talking to the sales rep, not actual tech guys).
Has anyone downloaded 3006 from myarchicad.com? Is myarchicad.com a part of graphisoft or is it someone else's separate page? Seems to look the same.
We both have the same build in our office, so maybe it's just a bug that hasn't been addressed.
Yes, myarchicad.com is part of Graphisoft, and is the primary download site. You have to sign up for an account and the system assumes you are a new customer downloading a trial, so you get some marketing emails.
That's where I got build 3006 and I imagine most other people did as well.
Regarding sales vs tech: "never" contact sales for technical information - tech support is a free call and they have the real scoop.
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
If you already have build 3003 installed, I don't actually recommend upgrading to 3006. Build 3006 is not a Hotfix, it's a newer version that we compiled after we found a bug that prevented build 3003 to be used in Trial mode.
If you have not installed ArchiCAD 15 yet, you should consider installing the newer build 3006 if you use Teamwork and still have ArchiCAD 13 projects. Please read about this problem:
http://archicadwiki.com/Bugs/Teamwork/LibrariesNotFoundAfterArchicad15Upgrade
But as a general practice we recommend to remove the BIM server 13 module before installing the 15 module. In that case, it does not matter if you have build 3003 or 3006.
A Hotfix for ArchiCAD will probably come later this summer.
Gergely Kmethy
