‎2010-03-09 10:35 AM
‎2011-02-11 08:28 AM
‎2011-02-11 03:49 PM
‎2011-02-14 12:06 PM
‎2011-04-06 03:27 PM
‎2011-04-06 03:30 PM
‎2011-04-06 03:32 PM
vfrontiers wrote:I have experienced the same issue...
2. Story levels are not consistent between the two macs... If I set up an elevation with story levels and all looks fine in elev window and layout, opening the elevation on the MacPRO... the story markers disappear... Then, when the layout is opened and the elevation is UPDATED, they are gone from the layout version as well.
Opening the same elevation back up on the iMac will show that the ELEV Markers are still SELECTED TO SHOW in the dialog box, but are not showing in the elev. window or on the layout. Typically either a REBUILD (not from model, crap that would be really horrible) brings them back or deselecting and re-selecting their visibility in the dialog box brings them back...
There are other more isolated incidents of items disappearing and changes not making it back to the host file, but virtually un-documentable...
Just wondering if others have experienced similar issues... I am ready to relegate the text block issue to the difference between Leopard and Snow Leopard... but cannot update mine without major overhaul of the contents of my iMac.
‎2011-04-07 02:08 PM
vfrontiers wrote:Duane:
BIMSERVER = iMac / OsX 10.5.8
Slave 1 = PC LAPTOP / Win7 64bit
Slave 2 = MacPRO (SF) / OsX 10.6.?
1. Text Boxes with the SAME FONT show up 20%-25% shorter on the MacPro. Making drawing around text boxes (like revision triangles) impossible to keep aligned... So, to be clear, when I open it up on my iMac, text boxes are longer and often run off the page... If I fix them, then they appear 25% shorter on the MacPRO. And, of course, this works in reverse. If text blocks editing on MacPRO, when I view them on iMac, they are longer...
In addition, when edited on the MacPRO, then looked at on the iMac, it is obvious that the text block (hotspots) are fixed in the place they were on the MacPRO, but the actual text is running over them...
‎2011-04-07 03:26 PM
‎2011-04-07 03:27 PM
‎2012-07-26 10:42 AM
