2023-02-14 02:03 PM
I would like to collaborate on a teamwork project on BIMcloud with a team working in GER (German) version and I have INT (English) version. All on Archicad26.
Does anyone know if this is possible?
Solved! Go to Solution.
2023-02-14 02:48 PM
Different language versions can work together in Teamwork with no issue.
Noémi Balogh
Community Expert, Admin
2023-02-14 02:27 PM - edited 2023-02-14 02:28 PM
There’s a post here suggesting there are no issues.
I know there is a requirement for the versions of Archicad to be within the same 100 build numbers so 4034 would be compatible with any build between 4000 and 4099. Different localisations have slight variations to the libraries and classifications which may cause issues. May be best to contact local support to be sure.
2023-02-14 02:48 PM
Noémi Balogh
