The Travel Pack is partially editable
I imported the travel pack file and open in offline mode. Some parts of the file is not editable. Any solution!
If I want to edit the file in offline mode. What is the proper way!
2 Replies 2
When you export a Travel Pack you can edit only what has beeen reserved while you were online, connected to the BIM Server.
So the solution is: reserve everything you need to edit before creating the Travel pack.
Thanks!
