Tip: restoring Deleted elements
Just a tip to those using TW2. Today a user came up at 5:00 with a big problem. A large portion of the project was missing. After a little investigating I discovered the user had accidentally deleted the missing elements. They were in his work space, and he needed them back. I thought about rolling back a copy of the project but decided against it. A coworker on the same teamwork project hadn't sent and received changes yet. On his computer I selected items not in his work space and fine tuned the selection manually down to the elements marked as deleted. CTRL+C + CTRL+V=Easy restoration of a mistake.
Hope someone else can make use of this.
0 Replies 0
