We value your input!
Teamwork & BIMcloud
Unable to hide layers
After mounting two modules in a TW-project I'm unable to hide layers.
Everything is visible even after hiding all.
Selecting an object gets gray nodes and the tool is not activated, deleting is not possible.
Quick layers doesn't work.
There's a support package for GS if u r interested. Just mail me a download link.
7 REPLIES 7
Erwin Edel
Locked elements perhaps?
Edit > Locking > Unlock all
Ghost elements related to GPU driver problem? Try updating those.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
No nothing locked Ervin.
Had another .pln open at the time and that worked fine.
Tried "select all" with arrow tool active and only got a couple of lines from the archicad layer although everything was visible and every layer hidden.
Erwin Edel
I've no experience with Teamwork, it seems it has it's own world of bugs
It's not a simple matter of trace reference?
www.leloup.nl
Windows 10 Pro
Erwin Edel
Oh and renovation filters / settings sometimes give strange results too.
www.leloup.nl
Windows 10 Pro
I would say it sounds like trace reference is on with original element colours so it would look like the real model.
Sorry but there's no trace reference on and no renovation status issue.
Even if I had a trace reference on it shouldn't show everything when all layers are hidden.
If the trace reference is of a View in the View Map then it uses the layers saved with that View regardless of what you set in the layer settings dialogue.
