‎2003-11-20 08:08 PM
‎2004-01-06 10:38 AM
Ted wrote:ted
I may be thick about this, but satellites seem to need/want to read the parent library if it is available on the network so any time savings is out the window.
‎2004-01-06 04:49 PM
‎2004-01-06 05:16 PM
‎2004-01-12 05:46 PM
~/archiben wrote:Matthew and Ben, I haven't thought through the +/- of PLAs, but I think what I am suggesting is a preference in ArchiCAD that dictates whether the Library Manager automatically goes out to the MSFS libraries (mother ship file server over the network) OR let the user initiate when the libraries compare (whether they are offline or not)...
i too would like to see archiCAD check the network library if it has a connection, but ignore it and just load up the cache libraries if not - much in the same way that opening a teamwork draft offline operates, i.e. 'could not validate, etc... you are working at your own risk'.
~/archiben
‎2004-01-12 07:18 PM
~/archiben wrote:I don't think my tests yielded any of the "WAY quicker" part...
you are right - at every draft open, sign-in or send and receive archiCAD requires that the network libraries be present. however after comparing the server library with the local cache, archiCAD proceeds to load up the local cache WAY quicker than loading across the network
~/archiben
‎2004-01-12 11:42 PM
‎2004-01-12 11:59 PM
Matthew wrote:I look forward to what you find out. I will run subsequent tests here. I am taking the position that all of our projects will be run in Teamwork. I have wondered that if Workstation Z signs in and the standard library is loaded from ZeusHD>ArchiCAD>ArchiCAD_Library and then Workstation A wants to sign in if they will be asked to find the absolute path of ZeusHD>ArchiCAD>ArchiCAD_Library across the network. Hopefully Workstation A will get to use AthenaHD>ArchiCAD>ArchiCAD_Library...! If ArchiCAD handles it the way I would like, then I will simple make the local copies of the standard libraries read-only (MacOSX) and all should be good. Thanks in advance. I'll be tuned in...
For the time being it seems that the best practice is to keep the changeable libraries (the project libraries) on the server and keep the standard libraries on the local machines.
It may be that if the standard libraries are in the ArchiCAD application folder they will be found automatically when a project is opened on different machines, but I haven't tested this yet. I am also not sure how this might affect teamwork, but it should probably be OK.
‎2004-01-13 04:38 AM
‎2004-01-14 08:19 PM
Millard wrote:We've found the same problem, Millard. Unfortunately, each machine in our office must have its own identity for the network backup system to work. It also would make it hard for a network administrator to fix problems remotely.
I have found that having different paths on different workstations causes a problem with PLN linked views when updating from plotmaker. It would be better if all of the hard drives had the same generic name.
‎2004-01-14 11:55 PM
