matjashka
VPN disconnect, only when sending TW snapshots
Hello All,
I have a persistent problem with Teamwork snapshots:
About 8 out of 10, my VPN tunnel gets dropped when sending an ArchiCAD .pln snapshot, the file size can vary between 150-200MB. Re-trying cost me a lot of time at the end of the day, and we need those snapshots to be safe.
According to all logs, VPN server drops connection because the Mac OS VPN client became unresponsive.
Note: this is not a site-to-site tunnel, it's a tunnel between server and a single Mac.
I can successfully send larger files over the same VPN tunnel without such problems. ArchiCAD sending a snapshot file somehow causes the Mac to stop responding to VPN ping-back during transfer. I've been monitoring my ADSL line as well, and its quality does not seem to be the problem, attenuation is very good, noise margins are stable, there are few errors, etc.
Does anybody have a faintest idea what may be going on?
Possible fix: ArchiCAD has ~30 second timeout (can't say exactly) and if I manage to reconnect the VPN quickly then ArchiCAD will successfully retry. Is there a way to modify that timeout to at least 60 seconds so I have the time to re-open the tunnel? This is far from ideal, but at least it's been tested to work.
Thanks!
Matt Krol [LinkedIn]
BHMS Architects and Planners, Chicago
AC 10 ... 26 USA
3 Replies 3
schagemann
Assuming you are using a mac - please update your signature with details on OS and AC versions, have you checked the following:
1. System Preferences > Network > VPN Profile > Advanced > Options > enable Send all Traffic over VPN Connection
2. From memory there is also an option to compress network traffic in the WE somewhere... sorry can not check at the moment, but this option might only apply to BIMCLOUD traffic...?
Hope that helps.
VKTRS | macinteract
Design Technology Managers - all on macOS | since AC 6
Archicad Framework > Smart Template 28
Smart Tree, Transmittal and Universal Label plus other smart GDL Objects
matjashka
Yes, using a Mac. After trying different scenarios (including the ones you proposed) and observing network conditions it became clear that this is some type of protocol implementation problem on either end.
I'd recommend any ArchiCAD user to stay away from L2TP/IPSec.
We switched our entire office over to OpenVPN (using the same appliance) and all the problems disappeared, as I anticipated.
I don't know why Apple does not have a built-in OpenVPN client in 2020, but maybe it's better that way.
Thank you for your response.
AC 10 ... 26 USA
schagemann
Interesting - we have not had any problem with L2TP & IPSec so fat at all.
Can I ask which version of macOS you are on and what is providing the VPN service on the server side?
VKTRS | macinteract
