Mats_Knutsson
Mentor
Virtual servers and ArchiCAD?
Does anyone run BIM server on virtual machines? We have an idea (but no hands-on knowledge) about running ArchiCAD BIM Server on virtual machines (wm ware) to reduce down-time if there is a hardware crash. Possible/smart/stupid/go/no-go?
Best regards,
Mats
AC 25 SWE Full
9 Replies 9
Link
I personally don't have any experience with it, but I know a firm in Melbourne that has successfully implemented their BIM Server on a virtual machine.
Link.
Hi Mats!
I've kept a training in a technical college with twenty pupil group in teamwork, BIM server running in a virtual server managed by their IT dept.
We modeled identical single family houses, one for everybody. I don't know the installation behind but it went well.
All Finnish basic trainings are kept in teamwork. We have a macmini as a server, and a laptop class (cable network).
Ville
Mats_Knutsson
Mentor
Thanks both! Will probably do this.
Mats
AC 25 SWE Full
We are running it in Windows Hyper-V without any issues. It was a little tricky getting the usb to pass through to also run the protection key on the VM.
Hi Michael,
Could you kindly elaborate on how you manage going around the issue with the Key being seen in the VM?
Thanx,
Yves
To use USB in the VM there is a 2 part software instalation. The main server is running a server and inside the vm is a client./ This is the software to make it work.
www.fabulatech.com/usb-over-network.html
Hope this helps.
Best regards,
Mats
Our company runs a bim server successfully on a vm. What would you like to know?
Mats_Knutsson
Mentor
Best regards,
Mats
Thanks! I just wanted to know that it works! We will start virtualizing with wm-ware in a couple of weeks. Mats
AC 25 SWE Full
Mats_Knutsson
Mentor
Already end on january...
We've been running the BIM-Server on a virtual host with VM-ware for about a month now and everything is working fine.
Mats
AC 25 SWE Full
