pejotu
project altitude in teamwork
We have a project template, with the altitude set to +7,37 (to be changed for each project, obviously).
A new project recently started on this has the altitude +8,32.
Two issues have surfaced:
- in this BIM server project, each new user by default receives the template altitude +7,32, rather than the real project altitude, and has to manually correct it in the project location settings
- the AC17 coordinate object, for displaying a point's coordinates in plan view, diplays the altitude according to the template altitute 7,32, and there seems to no way to correct this
Anyone with the same issue?!
(AC17, Finnish, build 5014)
Marton Kiss
We recently optimized this field to make sure the project location settings require reservation and all changes are synchronized with the BIM Server. This will be available starting from ArchiCAD 18. Until the release I recommend to save a pln of your template, set the altitude and share it again on your BIM Server.
I hope this helps,
Marton
Marton Kiss
Chief Product Officer
GRAPHISOFT
