teamwork library problem with library part macro
i'm having an annoying issue with one library part in a teamwork project;
i've successfully shared the project, which uploaded all embedded objects to the BIM server; i noted that this particular object was not appearing on plan (placement dot only on plan) and when i open it it tells me that a macro called in the master script cannot be found. i did a search for the macro name and it's in our office library, it's in the same folder as the part.
using the "manage bim server libraries" function, i uploaded our office library folder to the bim server, checked that it had successfully been added. I then reloaded the project from the bim server - but the library part still indicates that the macro can't be found.
any assistance or insight into this issue appreciated.
rob
0 Replies 0
