2014-04-23 10:13 PM
2014-04-25 03:34 AM
yukioMishima wrote:I don't know what can be causing that, you might want to contact your local support about that.
01: experiencing huge delays in receiving messages... any help on where / what / how we can resolve
02: not always clear in the teamwork palette which items a user has reserved (sometimes there is a little green jellybean next to a reserved view... sometimes not)Are you talking about elements in a Viewpoint? You can display all such elements reserved by you by using on of the display modes in the Teamwork Palette, like "color by users" or something.
03: is there any setting that allows a pop-up message to show when a user has.. for example.. sent & received, released a view etc.... so that others working on the project are aware of what is going on
04: is there any way to change an exist view maps settings (pen settings, associated layers settings, reno filter etc)... i can open the settings dialogue box... make the mods... but the OK button is greyed out... is it not possible to change... irrespective of your role... is it only possible to go back to the project map... and recreate the view with the correct settings?I think you will have to reserve the View Settings Dialog to be able to do that. But I think it is Role-dependent whether you can so you will have to check your Role to see if it allows you. If you go to the Dialog and the OK button is gray and you don't even see a Reserve button, your Role probably does not allow you. If I remember correctly, in such a case you have to modify the role or assign another Role i nthe BIm Server Manager, then you need to log out of the PRoject and them Log in again for the new Role settings to take effect.
2014-04-26 07:38 PM
2014-04-29 12:01 PM
2014-04-29 05:15 PM
