BIMcloud logs and diagnostic data
General BIMcloud logs locations
The following folders contain log and database files that are useful for troubleshooting.
WindowsmacOS
BIMcloud Manager log files C:\Program Files\GRAPHISOFT\BIMcloud\Manager-<Date>\Logs
BIMcloud Manager data files C:\Program Files\GRAPHISOFT\BIMcloud\Manager-<Date>\Data
BIMcloud Server log files C:\Program Files\GRAPHISOFT\BIMcloud\Server-<Date>\Logs <Date>: The date the installation took place in YYYY-MM-DD format.
BIMcloud Manager log files System drive/Applications/GRAPHISOFT/BIMcloud/Manager-<Date>/Logs/
BIMcloud Manager data files System drive/Applications/GRAPHISOFT/BIMcloud/Manager-<Date>/Data/
BIMcloud Server log files System drive/Applications/GRAPHISOFT/BIMcloud/Server-<Date>/Logs/ <Date>: The date the installation took place in YYYY-MM-DD format.
Installation log files
The following folder contains log files that are useful in case of BIMcloud installation and update issues.
WindowsmacOS
C:\ProgramData\Install.GS
Note that the ProgramData folder is hidden by default. See how to show hidden files on Windows.
System drive/Users/Shared/Install.GS/
Note that you might need to give read permission to all users to the Install.GS folder to be able to compress the log files. See how to give read permission to folders on macOS.
Locations of older BIMcloud and BIM Server logs
Browse more articles
Back to articles
