2 queriesbout openGL
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2008-12-22
05:51 PM
‎2023-05-11
02:09 PM
Noemi Balogh
‎2008-12-22
05:51 PM
Im using OpenGL in Archicad and it looks good execpt 2 things :
the sun im using is always in 1 direction unless i change it. when i show a client the model - some part of the model will always be better shown
others - in the drk (mostly it happened to 2 side of the house)- i place the sun generally in the corner direction to recieve at least 2 side with shade differences. is there a way to create another sun or maybe cancel it and light everything the same ?
also, is theere a way to show all wireframe togethr with the shaded model but the wireframe all in black without changing each object, wall ect lines-color ?
hope im clear...
thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-22 06:31 PM
‎2008-12-22
06:31 PM
The sun will not move when you navigate. But, the sun position - along with lots of other settings - is saved with each 3D view.
So, simply save a few different views (each with a different sun position) and switch views when things seem too dark.
Not sure what you mean about the wireframe....
AC 28 USA and earlier • macOS Sequoia 15.3.2, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2008-12-22 10:03 PM
‎2008-12-22
10:03 PM
Turn up Ambient light to fill shadows. Adjust intensity balance between sun and ambient to soften the effect.
For wireframe edging on a solid model all the same color, enable the Special Menu [search for it on the forum to get the directions - complex] to enable drawing all lines with pen #1 in the internal 3D engine.
Dwight Atkinson
