Visualization
2022.1 Preview and Archicad
rbialosky
I just installed 2022.1 and I also installed the Archicad Plug-in just in case it was updated.  I think I did everything I usually do when I link an AC file to TM but when I import the AC file I don't see anything.  I've gone back and refreshed the link but there's not change.  I also played with the Z axis in case my model is under the ground or up in the air but that doesn't help.  There must be some setting that I don't have right.  Now I can't link the file to 2021.1.
1 REPLY 1
The only Archicad plug-in for some time has been the Datasmith link.  Is that what you're trying?
See:  https://community.graphisoft.com/t5/Document-Visualize-forum/New-Datasmith-Direct-Link-Archicad-25/m...
