3D Grass & Water in Artlantis
I am slowly learning Artlantis, but I want to know 2 things:
How do I make 3d grass like seen below:
And also, how do I make realistic looking water like seen below:
Thank you VERY much for any help.
3 Replies 3
The water i think it's default water shader from artlantis (be careful do not have any additional textures on the material)
and the grass i think it's added later in post production from a real photo.
Yes, the animated water is a standard shader. The grass is most easily done using the free ArchiRadar grass downloads. Visit the Artlantis forums for this and other information Artlantis information, as you'll be talking to the largest Artlantis audience there. 😉
Ok, thank you very much. My water always looks awful, but thats probably just because I usually am too lazy to make my own pools, so I just use the default Archicad pools.
