Jason,
I am glad to inform you that the native
ArchiCAD 9 compatible Google Earth add-on is available for download. Although, it is still in beta phase, we would like to share it with you, and ask for your contribution in the testing and evaluation process. Please, feel free to share your thoughts either in this thread or in a personal message. All comments are welcome, I am eager to get your feedback how we can make this tiny add-on as useful as possible.
Usage: The Google Earth ā ArchiCAD data exchange is quite similar to Sketchup:
- Download the attached GE.zip and unpack it.
- Backup and then replace the ā
jack.dllā file in your ArchiCAD 9 folder and copy the ā
Google Earth In-Out.apxā under the [
Add-Ons\Import-Export] folder.
- Download and install the latest Google Earth program (
http://earth.google.com
- Create Google Earth placemarks, polygons, or paths. (Polygons and paths can be generated from Google Earth Plus or Pro) and export them.
- In ArchiCAD you can either open or merge the Google Earth KMZ/KML file.
- Once you have positioned your model, switch to 3D view and save your work into Google Earth format.
Itās quite simple, isnāt it?
Note: Macintosh platform is not supported yet, but we will soon release the compatible version.
