‎2023-10-19 06:30 PM - last edited on ‎2023-10-21 05:04 PM by Karl Ottenstein
I'm running AC27 Solo and have noticed it is missing the Sketch Rendering Engine. Tech support confirmed this, but they were not sure if it is missing by design or it's a bug, so they're checking with HQ.
In the mean time, those of you running AC27 Full, do you have this engine or is it missing too?
Solved! Go to Solution.
‎2023-10-24 10:31 PM
Update and workable solution –
I heard from my tech support:
"Hello Florin,
Here is a link to the Intel verion: https://graphisoft.sharefile.com/d-s485b0dd096764a3baa13d39fdf22914c
Here is a link to the Silicon version: https://graphisoft.sharefile.com/d-s1b9ff7b8d39d4f61b8c85adfaca82a3f
These are for the USA version Archicad 27.
There is no problem with anypne downloading the full version and installing it for "spare parts."
Thank You,
Kevin
Senior Technical Support Consultant
Graphisoft"
I tried those links (Intel in my case) but it did not work! Same messages as reported above (I think even the link is the same).
However, we got the green light to download AC27 Full and copy the files from there. It worked for me so that's why I said we have a workable solution until and unless we hear from GS Tech Support as per Karl's message above.
‎2023-11-21 01:25 AM
Hi All,
Thanks for your report and input. This is a known issue, DEF-16830, the Sketch Render was left out from Archicad 27 Solo by mistake. It will be fixed in Archicad 27.1.1. In the meantime, please:
I hope this helps.
Kind regards,
Arash
‎2024-03-01 05:18 AM
Thank you, Arash. Simple and easy. It worked.
Just wondering, what else is there that we (Archicad Solo) can take or have following the same process, that can be incorporated into the SOLO version?
