AC19 white window instead of render
after installing AC19, when I want to make render, white window appears and nothing is going on - only timer is ticking.
On the prewiev window also render doesn`t appear.
Restarting my computer or archicad doesn't help...
Unfortunetly I have problem with each project, the same files saved and opened in AC18 renders ok.
Somebody help ? 😉
1 Reply 1
Update no 4011 is the culprit 😉
