Visualization
Render your model with built-in or 3rd-party solutions
SOLVED!
After Effects
Are there any After Effects users on this board? I'm actually pretty new to the program and I wanted to know if anyone can provide me with any sort of tips for importing sequence footage from Maya, AutoCad or ArchiCad. I've heard that this program will be particularly important for look-arounds.
So. . . anyone use it? I'd love to heard some tips from fellow architects!
1 ACCEPTED SOLUTION
Solution
I´ve been using After Effects CS4 for the last 5 months so I can say little about it.
I dont produce my footage in Maya, AutoCAD or ArchiCAD. I rather use Artlantis 3, but I think the logic for importing would still be the same. So here is what I do so far: I like to export my animation from Artlantis in frame sequences in JPG or TIFF format, usually in 15 FPS or higher. Then using this bunch of images I can build the secuence in After Effects.
Hope it helps.
1 REPLY 1
Solution
Hope it helps.
