Visualization
Aliased 3D Window Output
derekjackson
when we work we often save out quick views from the 3D window as JPGs to discuss as we design a model.
In previous version of ArchiCAD, the output would look nice and anti-aliased, much like the better OpenGL settings.
It seems in 19 that even though I have OpenGL active in the 3D Window Settings, saving from the 3D window outputs a horribly aliased version that looks more like the Internal Engine.
My process is exactly the same as in previous versions (navigate in the 3D window, then choose File, Save As) - am I missing something?
http://www.lsiarchitects.co.uk
http://derekjackson.artstation.com
AC19 / 21 / 23 / 27
Windows 7 Intel Xeon 18Gb
Erwin Edel
Think this was discussed a while back, as I recall changing the 2D anti-alias setting in work-environment had influence on how the 3D view was saved.
Options > Work Environment > User Preference Schemes > Advanced Redraw Options > 2D Drawing Antialiasing
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
derekjackson
Yep, that's done it - ticking the 2D box fixes the 3D...
Thanks!
AC19 / 21 / 23 / 27
