2013-02-19
12:10 AM
2023-05-11
01:17 PM
Noemi Balogh
2013-02-19 08:37 PM
2013-02-19 11:44 PM
Tom,See the pic below.
I was struggling to understand the cause of the problem for sometime and then the lightbulb went on. The points on the photo create a perfect rectangle, zero perspective. This situation leaves ArchiCAD unable to reconcile the placement of the camera since the triangulation is not possible with the command as it is currently. I think this is a bug and I am reporting it to HQ.
So what to do? It might make sense to use the picture as a texture on a wall or morph element and place the element at the facade of the building location.
Another alternative is to manually align the view. Start with the camera that is placed at the Hotspot in the corner. Then simply pan and zoom (do not orbit). You will then have to change the view cone. I found about 50 degrees or so works.
But in the end the tool should work in this condition so hopefully they can fix it. Please let me know if you have questions or comments.
