2012-11-21
02:23 AM
2023-05-11
12:06 PM
Noemi Balogh
2012-11-21 03:03 AM
2012-11-21 03:35 AM
Dwight wrote:Hi Dwight, thanks for the reply. I have tried lowering it to 100 dpi. No avail. Still errors out with "Not enough disk space.."
That is a ridiculously dense rendering.
Keep your rendering to less than 4000 pixels on an edge.
150 ppi is plenty for an A3 print.
2012-11-21 05:36 AM
2012-11-21 10:19 AM
Dwight wrote:A little ban mishap but I am back.
Then it must be your background image. Can you fix the native resolution?
2012-11-21 08:29 PM
2012-11-22 10:05 AM
Dwight wrote:Thanks for all your help so far Dwight. It turns out, your suspicion is right about the background image. Once I removed the image, it rendered. I then put the image back in and tweaked the image size. The project then rendered!!
That is a big question.
Printing to an inkjet, it will be fine.
However, you need to know that Archicad's textures don't support really high resolutions - they will blur in the rendering.
The most glaring error here is where the rendering is made sharper than the photo background.
Equipment varies.
