Amateur user - Rendering error: Not enough disk space..
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-11-21
02:23 AM
2023-05-11
12:06 PM
Noemi Balogh
2012-11-21
02:23 AM
I am amateur user using Archicad 16 for my uni assignment. I know this type of post have been posted many times in the past and I have been reading through many, many of them but still I couldn't resolve the issue that I am encountering on my Macbook Pro.
I have been trying to render my project on my macbook pro which I have purchased 8 months ago. Its specs are Intel i7 2.4GHz and I have put in 8GB RAM.
When I try to do a photo-render using the Lightworks engine for an output of A3 size (41.91 cm x 29.72 cm) with 600dpi (I also have an background image inserted)
I straightaway get a "Not enough disk space to render" error followed by an "Not enough memory.." error.
I have checked my free disk space on my machine: 300+ GB free at the moment. I also ensure that I reboot my machine and Archicad is the only running application before I proceed with rendering. Also I have tried to turn off many of the options, such as effects, lighting, shadows. But I still get the error almost straightaway when I start the render process.
I have also tried to reduce the size and dpi but that's not really an option because I have been instructed to produce the render in that size for my assignment.
Can anybody help? Any suggestions? Do I need a more powerful machine?
I have been trying to workaround this for the past week non-stop but still no luck.
Thanks all!
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-11-21 03:03 AM
2012-11-21
03:03 AM
That is a ridiculously dense rendering.
Keep your rendering to less than 4000 pixels on an edge.
150 ppi is plenty for an A3 print.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-11-21 03:35 AM
2012-11-21
03:35 AM
Dwight wrote:Hi Dwight, thanks for the reply. I have tried lowering it to 100 dpi. No avail. Still errors out with "Not enough disk space.."
What the hell is wrong...Could this error be a generic error that is masking something else?
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-11-21 05:36 AM
2012-11-21
05:36 AM
Then it must be your background image. Can you fix the native resolution?
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-11-21 10:19 AM
2012-11-21
10:19 AM
Dwight wrote:A little ban mishap but I am back.
So, may I ask if I try to render this at a lower dpi i.e. 150 at A3 size. Will that still achieve photo quality? I will need to be printing this render out, so I want to make sure that at 150 dpi, it is still a high quality image for me to print out in A3.
Thanks.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-11-21 08:29 PM
2012-11-21
08:29 PM
That is a big question.
Printing to an inkjet, it will be fine.
However, you need to know that Archicad's textures don't support really high resolutions - they will blur in the rendering.
The most glaring error here is where the rendering is made sharper than the photo background.
Equipment varies.
Equipment varies.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2012-11-22 10:05 AM
2012-11-22
10:05 AM
Dwight wrote:Thanks for all your help so far Dwight. It turns out, your suspicion is right about the background image. Once I removed the image, it rendered. I then put the image back in and tweaked the image size. The project then rendered!!
Equipment varies.
Thank you!
