2014-10-1312:13 AM - last edited on 2023-05-1101:23 PM by Noemi Balogh
2014-10-1312:13 AM
Hi!
I have a problem and I count on your help.
When I do an animation video of a journey in archicad, a house for example, there is the possibility of animation that make a material part of a wall, floor, disappears to can see inside where pipes are located (wall and radiant) floor?
If yes, how i can do that?
You can include a (semi) transparent material in your animation and model pipes within it. Just check the transparency settings in the surface settings.
But you can't animate something turning transparent as you move through the animation if that's what you mean. Perhaps you could with GDL coding of a special part.
