2014-11-05
07:37 PM
- last edited on
2023-05-11
01:03 PM
by
Noemi Balogh
2015-05-21 05:21 PM
Csaba wrote:Hello,
Dear Emmanuel,
The flickering problem will be solved in ARCHICAD 19.
Unfortunately we can't implement the entire feature set of Cinema 4D into ARCHICAD, so if you need the full functionality you have to export the ARCHICAD model to C4D with our export Add-On. This C4D file contains all surfaces/attributes and your rendering settings as well, therefore you can continue work in C4D exactly where you left it off in ARCHICAD.
Exporting the Fly through path is not an option just yet so I have added your report about it to our wishlist.
We plan to update the CineRender Engine in the next ARCHICAD versions to utilize MAXONs new technology.
Best regards,
Csaba
2016-06-16 12:05 PM
2016-06-17 01:31 PM
